So my head gasket went, and I began to replace it. Upon pulling the head, I knew I needed to have it machined down. Took the head in and was told it was beyond repair, so I bought a new ( Reconditioned one) with new rocker arms, springs, fulcrums, etc. Got a felpro gasket set. Replaced timing belt and water pump while I was in there. I followed my Haynes book carefully through the whole procedure. I was very meticulous in removing old gasket material. The block did not seem to be out of true. I used a GOOD torque wrench when necessary. When I changed the oil after all the work, a lot came out, but I just assumed a little water got in from backflushing the rad. What are some avenues to consider? I just don't know where to look. There was literally a coolant/oil mixture spewing out the dipstick tube upon getting back from the first quick 1-mile test drive after completion, and like I said, I just changed the oil. It starts and runs immaculately, aside from the aforementioned issue (I thought I had it until I opened the hood) Please help! Before I push this darn thing off a cliff!
-Brownie
-Brownie
