Rear wiper wont shut off | Ford Escort Owners Association (FEOA)
Discussion in 'Electrical' started by Datsu, May 15, 2020.
  1. Datsu
    Datsu FEOA Member
    23
    Ok so i'm either very very stupid and don't know how to work the rear wipers on my 93 wagon or somethings actually wrong. But they wont shut off. I didn't press anything to turn them on or anything. Whenever I start the car they just automatically turn on and I cant do anything about it. For now I've just unplugged the fuse but I would like to know what is wrong.
  2. pextor
    pextor Moderator Staff Member
    5,911
    778
    Lancaster, pa
    The wiring between the hatch and body is probably starting to fail. I've had to redo a couple of my wagons over the years because of this issue. The way I fixed them is go to the junkyard and cut a foot of wiring out of another wagon from inside the car to patch in.
    Datsu, denisond3 and Pizzaman5000 like this.
  3. Pizzaman5000
    Pizzaman5000 FEOA Donator
    1,471
    439
    183
    Central OH
    Yeah the problem is probably inside the rubber accordian.
  4. Datsu
    Datsu FEOA Member
    23
    Thanks, that helps. I'm assuming just cut the old wire out and heat shrink the wires together. I also just realized the tail lights don't work either, only the brake lights. So I'm hopeful its just the same problem as the wipers. At least the car inst in pieces anymore like it was. Shitbrickford .jpg
  5. pextor
    5,911
    778
    Lancaster, pa
    You want the wires to be "new" in the accordion piece. You don't want the repair to be in there, or it'll fail again much quicker.
    Pizzaman5000 and Datsu like this.
  6. Datsu
    Datsu FEOA Member
    23
    Yea I can see how 20+ years of constantly bending would do it good. It occurred to me that I should probably do this to other parts of the car too. Doors specifically.
  7. pextor
    5,911
    778
    Lancaster, pa
    I've never had to do it to doors, but I can see how it could be a problem.
    A friend of mine had to redo the wiring in the doors of his 2003 Dodge Ram pickup for that same reason.
  8. marclar
    8,881
    505
    seabeck WA
    super common on all cars. every time the wire flexes it work hardens it a bit. i fix them all the time..
    another common over sight, is the 'park' switch inside the motor fails. this is what cuts power to the motor its self. once supplied power from the switch, the motor runs on its own effectively. without the park switch interruption they can run forever until power is cut completely.
