1 - 3 of 3 Posts
Hello:
Does the following energy suspension part
fit on 2nd gen escort?
ES p/n 4.7123G
Rear Trailing Arms
97-99 Ford ZX2
Or maybe there are some rubber aftermarket
bushings available for 91-96 escort?
Thank you,
Rob.
as far as ES suspension parts - the trailing arm bushings from the zx2
work i hear... another 2nd gen wagon owner has done this and says all is
good.
That was the reply I got from Rob Green of ZXTuner via e-mail when I asked the same question.
:wink:
AFAIK (as far as I know), there is little-to-no difference between the suspension bits from 91+, but the companies who build the parts aren't going to risk a bunch of returns since they've only tested them on the specific vehicles they built them for.
I used the ES ZX2 bushings on both front and rear on my Protege. So yes, They will fit the 91-96 EGT.
front LCA's
front sway bar endlinks
front sway bar frame mounts
rear trailing arms
the only ones that i bought that didn't fit, were the steering rack bushings.
1 - 3 of 3 Posts
