rear rotor bolts | Ford Escort Owners Association (FEOA)
rear rotor bolts
Discussion in 'Wheels/Tires/Brakes' started by copcarguy, Jun 5, 2014.
  1. copcarguy
    copcarguy FEOA Member
    1,980
    847
    263
    Northeast PA
    Hey all!
    Anyone know the part number of the two big bolts that hold on the rear rotors on a 3rd gen? I boogered one up recently and want to replace it. Thanks!
  2. Gamer92
    Gamer92 FEOA Donator
    3,435
    980
    263
    Southern Indiana
    You could probably just put the wheel back on without them. I have drums and I have left my bolts off of them and have had no issues without them.
    copcarguy likes this.
  3. TexasTracer
    TexasTracer FEOA Member
    4,694
    16
    188
    Sunnyvale, Texas
    Most auto parts stores should have them in a little package.
  4. denisond3
    9,934
    2,699
    If you mean the wheel studs, you can buy a replacement hub, with bearing and new studs. Also, most studs are pretty standard items, if you can get one off intact to use as a guide.
  5. zzyzzx
    14,766
    1,108
    I think they are referring to the countersunk phillips flat head screws that hold the drum on. I would suspect that they are M6-1.0 - 10mm length bolts.
    [​IMG]
  6. copcarguy
    1,980
    847
    263
    Northeast PA
    image.jpg Yes they are the countersunk Phillips bolts, but not that long. I'll put a pic up from when I just did my rear brakes. Thanks to all for their replies so far...
  7. denisond3
    9,934
    2,699
    I tend to reuse those countersunk bolts, if they arent too mushed up from being loosened with my impact tool. Otherwise I throw them out. The wheel clamps the brake drum or rotor in place anyway.
  8. Gamer92
    3,435
    980
    263
    Southern Indiana
    I'm not sure if they can be found at a place like ACE or not. I know they are a pain to remove at junkyards without a good screw driver, or an impact driver.
  9. copcarguy
    1,980
    847
    263
    Northeast PA
    They are also a pain to remove in your driveway as well lol
    LariRudi likes this.
  10. chestypuller
    chestypuller making the wifes commuter better
    1,008
    190
    163
    alaska
    What year did escorts get rear discs id like some of them to swap on!
  11. madmatt2024
    madmatt2024 FEOA Member
    9,830
    398
    383
    Upstate N.Y.
    ^ 91-96 Escort GT's, LX-E's and Tracer LTS's. ZX2 S/R's also have them as well as some 3rd gens.
    copcarguy and chestypuller like this.
  12. 300ZXRB26DETT
    300ZXRB26DETT FEOA Member
    1,012
    21
    288
    PHX, AZ
    Throw those bolts away since they are not needed. I toss them anytime I have to remove them since they serve no purpose except for the assembly line at the plant before the wheels/tires get put on.
  13. schwinnman67
    schwinnman67 FEOA Member
    311
    77
    178
    Colorado
    I've seen 4 sets on 97 Tracers lately ( I got one for my ZX2).
