Rear parking brake cables | Ford Escort Owners Association (FEOA)
Discussion in '2nd Gen 1991-1996 1.8L DOHC' started by BOSS302man, Mar 3, 2013.
  1. BOSS302man
    BOSS302man FEOA Donator
    2,665
    44
    198
    Lebanon, PA
    What is everyone doing about replacing the disc brake cables? I can easily find the front and right but not the left side. Appears nobody is making it any more. I would think I'm not the only guy in this position.
    Can anybody help?
  2. 300ZXRB26DETT
    300ZXRB26DETT FEOA Member
    1,012
    21
    288
    PHX, AZ
    rockauto, cost you about $50 for the pair
  3. BOSS302man
    2,665
    44
    198
    Lebanon, PA
    Yea? I looked and they didn't list the left side. Have a part number?
  4. Cymmantix
    Cymmantix My old archenemy, RAKES!
    6,141
    209
    363
    NJ
  5. BOSS302man
    2,665
    44
    198
    Lebanon, PA
    Wow! Thanks. I'll try the conversion trick as mentioned at the top.
  6. white-lightning
    white-lightning FEOA Member
    2,896
    186
    Salem, VA
    I work at Auto Zone and got a set of the rear sections last month, but returned them due to not needing them after the escort rear-ended another car. By the time it's fixed the weather will be above freezing and I need the money to fix my new dd.
  7. BOSS302man
    2,665
    44
    198
    Lebanon, PA
    So, what are you saying here that would help me? Not sure I understand.
  8. BOSS302man
    2,665
    44
    198
    Lebanon, PA
    Are you saying Autozone carries all 3 cables? Front, left and right? According to their website they don't. Have part numbers to share?
  9. 300ZXRB26DETT
    1,012
    21
    288
    PHX, AZ
    I looked up a 95 EGT since its the year of my car and all the rear parking brake cables listed are for disc brakes......it doesnt say so, but looking at the pics will tell you. The drum cables have a different end on them which is retangular hook, and the disc cables have the cylinder attached to the end of the cable, just like all the ones listed.
    I would recommend 3rd gen escort cables, but the part that attaches to the bracket on the caliper is different then 2nd gen ones.
  10. BOSS302man
    2,665
    44
    198
    Lebanon, PA
    3rd gen cables aren't even close. I looked just to see if you might have something. What you do is buy 2 rights and tear one apart and re-assemble to make it a left. All items are the same just assembled upside down.
    I now have a parking brake again! WooHoo!!
  11. PapaChach
    PapaChach FEOA Member
    88
    18
    158
    Dorman C94502 for Right Rear - Amazon $27.95 Prime
    Dorman C94504 for Left Rear - Amazon $54.99 free shipping
    Unless someone can prove me wrong, they look pretty much the same>???
  12. PapaChach
    88
    18
    158
    The only difference was that the expensive one came with the clips for both cables?
    I used the old clips because I didn't like the way the new ones fit.
  13. BOSS302man
    2,665
    44
    198
    Lebanon, PA
    No links on your post so not easy to check what your talking about. But the cables, although they look the same for a 2nd gen, they mount differently. Unless you modify a right side cable, it won't fit the left. I tried it.
  14. Bomdoutscort
    Bomdoutscort FEOA Member
    1,249
    10
    288
    Cincinnati, Ohio
    So does anyone have pictures of this conversion of using the right side on the left?
  15. BOSS302man
    2,665
    44
    198
    Lebanon, PA
    You really don't need pics. Once you have the cables and go to put them on, you'll see what to do. It's WAY easy to do.
