1 - 4 of 4 Posts
Hey all,
I've got a 92 LX wagon. I had a load shift in the car and broke the left rear side fixed window in the cargo area. Does anyone have a line on a source for a reasonably priced replacement?
In case not, are there any homemade solutions to replace the glass with some method and material?
Thank you in advance.
I replaced the windshield on my 91 about 10 years ago for around $200, you could probably get a new one for much less, or just call a jy for one. It shouldn't cost much to get and have it installed. You want a good reliable seal or your rear end will start to rust if it leaks, since you wouldn't see the water unless your looking for it.
Just hit up a junk yard. Shouldn't cost more than $30-40 for one off a junker. Cheaper if you hit a u-pull it yard.
Replacement
Do you have any tips on how to take apart one of these windows at the junk yard and then properly install it? Thanx
1 - 4 of 4 Posts
