1 - 5 of 5 Posts
I pulled the trim off my back window (non hatch) to fix some paint problems. I thought this car had trim you could just pull off. However after removal, i had leaks in my rear window, which i fixed with sillicone.
Anyway, the trim was stuck in two spots. on the other side there are two bolts. Does the trim bolt on, or does the whole window and trim bolt on?
I do not believe the trim is supposed to be removed seperate from the window.
1 - 5 of 5 Posts
