1 - 13 of 13 Posts
Does anyone know where I can get a rear bumper cover for a 1986-1988 escort gt? I’m also looking for a new set of headlights ( I’ve polished mine but I’m looking for a new set). Thanks.
You can convert your headlights to what 90s Rangers have, they have more aftermarket support and actually take the same shape of light - just have to revise the mounts behind it because the headlight mounting is different between them.
For the rear bumper cover you can use any 86-88 Escort/Lynx or EXP bumper cover or non-GT bumpers that are actual metal - I have a few if you're looking for something to get you by. For the 89-90 GTs you options are even more limited so you're more lucky than you think haha
Best of luck!!
Thanks a whole lot for this information. Is it hard to mount the ranger headlights or is it a fairly easy DIY job? I’m also wondering if its possible to cut the ranger lens and maybe epoxy it to the escort headlight housing. If so, I wouldn’t have to worry about revising the mount. Also, I’m gonna try to find the bumper cover but if all fails I may reach out to you regarding the metal ones. Thanks.
I'm not too sure, another member has done it successfully so he sells them. They have to have custom brackets so when you order a set from him you get the Ranger light units and the custom bracketry to mount them making them forever replaceable :D
I'm in Wisconsin, only got a few bumpers left!
Thanks 1982 EXPert. This is good stuff. How can I get in touch with the person that makes these custom ranger units? As far as the bumpers are concerned; you only have the metal ones right and not the rubber ones? Thanks .
I'll get his contact info but yes I only have the metal bumpers
I have a EXP bumper and lights, not sure if they fit a GT tho. If they do fit let me know I'm sure we could work something out.
I got the gentleman's contact info for the Ranger + Escort headlight conversion kits, if anyone messages me I'll share it to keep unwanted spam from him
Discussion Starter · #10 ·
[/QUOTE
[/QUOTE
Thanks. I'll reach out to you.
1 - 13 of 13 Posts
