1 - 3 of 3 Posts
okay well i cant get the lights on the ms to come on, i have no idea what happened or what caused it, is it possible i fried it? I never hooked anything directly up to the ms except for the relay cable. all other connections are from the relay board. When the key is turned forward all the relays will flick over but the ms itself wont power up. i have no way of accessing the ms if it wont power up. When i pull the relay cable out of the ms and put it in powered up i think i can hear the injectors open and then when you pull the cable out you can hear them shut... i think. Is there any way to test the ms?
If you can hear the injctors open by just pulling the fuse then the ms is stuck in "Injectir Test Mode" You should never hear your injectors without the car started. Double check your wireing. 9 times out of 10 all the problemns that would occur is due to the wiring. Double and triple check that..Believe me I have been down that road oh too many times before.
1 - 3 of 3 Posts
