1 - 5 of 5 Posts
Tie rod ends, ball joints, sway bar end links/bushings, upper strut bushings, rack bushings, calipers, loose change in the ash tray... :lol:
Did you replace your rear spring yet? They break like mad on these cars.
I'm also thinking that maybe your jack or spare tire could be loose.
If you are unsure if it's from the front or back of the car, check for a loose heat shield.
1 - 5 of 5 Posts
