Engine - Racing a 1.9 H.O. Need go faster parts | Page 2 | Ford Escort Owners Association (FEOA)
Engine Racing a 1.9 H.O. Need go faster parts
Discussion in '1st Gen 1981-1990 CVH' started by 88ESCORTV6, Jul 6, 2020.
  1. 1982 EXPert
    1982 EXPert FEOA Member
    158
    110
    53
    Nice! Don't forget to order an airbox for that and if you can swing it, a jet kit
    Here's a great source on how to go about jetting almost any Weber (scroll 1/3rd down the page to find "The 3 Circuits" section and go from there)
    https://jiminglese.com/weber-tech
  2. 88ESCORTV6
    1,280
    264
    333
    Hawkesbury Ontario
    do you have a link for the jet kit? and I will adapt my 1 barrels air box to it.
  3. austin86
    1,072
    353
    118
    Ohio
    Nice, let me know how the car runs with it. I realy wanted to put ether bike carbs or a 38 on my EXP but chose to stick with EFI since I had all the parts.
  4. 88ESCORTV6
    1,280
    264
    333
    Hawkesbury Ontario
    The Carb will be here in mid september so i got to wait.
    but man that shop in europe wow holly fk lots of parts for me there danST performance what a nice find.
    I will probably race it this Saturday.
    austin86 likes this.
  5. 88ESCORTV6
    1,280
    264
    333
    Hawkesbury Ontario
    would the EFI make more power then a well tuned weber 38/38?
    I need more RPM in this 1.9 best cam and valves you have a idea?
  6. austin86
    1,072
    353
    118
    Ohio
    From what I have read the stock carb on a 1.9 HO dose a tick better then the EFI form a performance stand point.
    So Im betting the 38 would be way better. But I cannot be sure as I never used a 38 before.
  7. 1982 EXPert
    158
    110
    53
    EFI will be better than a 2-barrel carb but that's mostly due to the intake manifold design more than whatever carb you use, unless you're clever with deflectors in the intake right under the carb the 2 outer cylinders will always be a little leaner than the middle 2 which make some difference in performance (like having multiple carbs out of sync with each other, this delays throttle response) and engine longevity if you're already a little lean to begin with you'll burn up your outer 2 valves.
    But dual Webers or bike carbs would be as good as or better than EFI obviously if you tune the carbs once fitted, it's just that the cost of high performance through carbs is a lot :/
    Follow the cam list I shared earlier in this thread, the roller EFI HO cam is the best of the best unless you can have one custom ground. Roller or solid lifters will allow you to reach 7,000rpm and beyond.
    You can try bigger valves and port the head, the pros in the UK found that increasing the intake valve size can make an easy 10hp before you do unshrouding or porting. But this depends on which head and cam you use..... When it comes to porting and valve sizes the rule with CVHs is not to enlarge the exhaust side unless you're turbocharging.
    But if you can port-match your manifolds and ports together that would certainly help. Polishing the exhaust port will go a long way too, it won't grant you much more power BUT it prevents carbon from accumulating which is a major flow-restrictor so you won't have more power but you'll have that power longer. Blending the seats is the biggest improvement for the time input, just blend the valve seats with the port's bowl/runner and you'll get about 18% more power across the whole rev range without having to change much if anything in your tuning (depending on how bad the seat blends were vs how carried away you get with the porting).
    Also try Harland Sharpe's roller rockers, the stock ones have a LOT of friction which translates to power-loss and valvetrain stress. Saw a video where someone put a set on a Jeep 4L in the dyno room and about 10hp was gained just by switching to Harland Sharp's rollers with the same rocker ratio. The graph was neat too, that 10hp difference was from idle all the way to redline!
    Check it out here and skip to 4:50 and keep watching till the end:
    88ESCORTV6 likes this.
  8. 88ESCORTV6
    1,280
    264
    333
    Hawkesbury Ontario
    Found air filter kit real cheap from Roush racing like 77$ CND shipped. ebay and others wanted 180 to 230$ plus shipping.
  9. austin86
    1,072
    353
    118
    Ohio
    That is why I chose to not use a carb setup. Its all those little things that add up.
