Alright, so i own a 4 door sedan, and there is a small problem with the passenger door, the power lock doesn't work, and the window goes down, but not up. i figure that the window doesn't go up because of the switch, cause the master switch can put the window up, just not the switch on the passenger door. so i went to the scrap yard the other day, and found the actuator for the locks off of a zx2, and it work perfectly, i was going to take the power window switch also, but i wasn't sure if it would swap over or not. so my question is, will they?
Thanks,
Shaun
Thanks,
Shaun
