1 - 3 of 3 Posts
going to put the intake manifold back on this afternoon but didn't see any little note or anything like you usually get with your felpro gaskets regarding the water passages.
should I run a bead of gasket sealer around the water ports on the sides of the gasket or spray the gasket with copper spray or anything before I put it on or just toss it on dry and be done with it??
When I did mine, I made my own paper gasket. When I put it on, I put a light coating of multi-purpose grease on both sides to get it to stick where I wanted it to while installing the manifold. Absolutely no problems to date. If you cleaned the mating surfaces properly, there's no need for sealer. So no you don't NEED to, but a lot of people put sealer on just to make themselves feel warm and squishy.
Matt 8)
1 - 3 of 3 Posts
