figured instead of starting a million threads that have "been covered a million times.SEARCH!" i'd just start one thread and keep all the turbo questions i come up with in here.
first one:maf:draw through or blow through?
second one: if the oil feed line that came stock on the turbo doesn't have a restrictor on it is it okay to just use some feed line for tht turbo or should it have a restrictor? (garret tb035h)
third one: as long as the turbo's oil drain is higher than the oil pan it will drain correctly, right? (this one is more pointed at alex because he knows EXACTLY where my turbo drain is.)
check a once over on my planned setup just to make sure i'm not missing nything:
t3 (aforementioned turbo)w/threaded wastegate so i can adjust the boost, but i was aiming for 6ish? (have ready access to e85 if needed)
custom manifold
2.5" downpipe
12:1 FMU
oil feed w/restrictor&drain to pan
intercooler 2" hard piping
stock ecu
1.9 injectors,1.9 maf(higher flow housing), 3.8 tb, portmatched intake mani.
missing any important details? leaving anything out that someone might want to mention?hoping to go MS sometime in the future to address the ecu/fuel bottleneck issue.
-Nick
custom manifold
2.5" downpipe
12:1 FMU
stock ecu
-Nick
