1 - 2 of 2 Posts
The guide wire for the drivers side belt in my 95 has broken/come loose and it sounds like the motor is just spinning around and making a thwacking noise. Is there an easy way to get to it to make it stop doing that without messing up the molding? TIA.
What I did with my automatic belts is; make sure the belts are in the back position as if your driving around and without opening the door; PULL THE FUSE. I just leave them hooked up and slide them over when I get in. Of corse I did this while my belts were fully operational. I read too many posts about broken automatic seatbelts.
1 - 2 of 2 Posts
