Just wondering if this seems plausable or if i should scratch out and drop one Sub.
Currently i have:
3 x DIAMOND CAR AUDIO D610D2 SPEAKER 10" SUBs
Sub specs are:
Impedance: Dual 2 Ohm
RMS Power Handling: 500 Watts
Peak Power Handling: 1000 Watts
1x Rockford Fosgate T10001bd 1000 Watt Class-bd Amplifier
Amp specs are:
* 1000 Watt RMS Class BD Amplifier
* RMS Power Ratings:
o 500 watts RMS x 1 at 4 ohms
o 750 watts RMS x 1 at 2 ohms
o 1,000 watts RMS x 1 at 1 ohm
Im wondering if i could use this set up as to i currently built a box to house all 3 Subs. im wondering if my amp has enough power to put out to the Subs with out causing any damage.
Currently i havent seen a way to wire them to have the same power going to all 3 Subs. one would have to be at 2 ohm and two would be at 1 ohm. Or so it looks.
If this doesnt look like it will work i can alway just get another amp and hook one sub up seperatly or just dirtch one all together.. But figured i would see if there is a way to make this work.. Blah! haha Thanks for your time and any comments.
This is my Box i made: (first time with Fiberglass)
Thank again!
Currently i have:
Sub specs are:
Amp specs are:
Thank again!
