I was weighing the better option. RTV sealant, or one of the various (non-paint) spray-on undercoats. Any difference between the "aero-rubber" (Bondo) and "rubberized" (EverCoat) ? Anyone with any experience with these brands ? Who's best ? EDIT: http://www.feoa.net/modules.php?nam...5&start=0&postdays=0&postorder=asc&highlight= /EDIT
Basically looking for the stickiest, thickest and most durable shyiat that'll almost literally survive hell or high (salt) water.
I know that RTV can be some nasty stuff, but application would be far less convenient and haven't looked into how/where to acquire enough of it. Probably need to acquire a sealant/caulking gun and tube from a hardware store; best guess.
But the undercoat that is already on the bottom of the vehicle, sides of the strut towers, and under far worse conditions, has held up beautifully. So what are your experiences and thoughts ?
BTW, the layers of rustoleum primer that I laid on there seems to have held up decent enough that I don't need to patch the tower. (but still need something better than just paint)
Would be nice to have a shaped/molded plastic insert to go over that planned undercoat or sealant.
On a side note, I'm pulling the rear back apart sooner than I intended. Started hearing a noise after a highway crater. Kind of like metal tapping on the back frame-body. Strange thing about the noise, only occurred over seduction (sinks into the road) bumps. Compression (raise off the road) bumps no noise. After some investigation, noticed rubber shavings sitting on top of the strut tower without the noise. Looked closer and noticed the rubber bushing there, on the replacement strut assembly had dry-rotted and was shearing. The bushing for the other side was just about gone; the strut bar crooked. So the noise I was hearing, was the strut-bar making contact with the strut mount or other, up top.
