Putting ZX2 gauge cluster in a sedan, 3rd gen?? | Ford Escort Owners Association (FEOA)
Discussion in 'Tech & Repair' started by kryztaly, Mar 30, 2018.
  1. kryztaly
    kryztaly New Member
    4
    As the title says, I read up in most places about it and they said the clusters were wired the same, just different styles. I really want to put the tach in my car but the cable clips are different ( The SE i want to put it into has 1 clip that has an extra 2-3 pins on the clip itself, making it too wide for the zx2 cluster).
    Does anyone know how-to do this? the junkyard doesnt allow returns under normal circumstances.
  2. FordMan59
    FordMan59 FEOA Member
    4,548
    441
    333
    Russellville, Kentucky
    You'll need to find a tach cluster out of a standard Escort not a ZX-2. The cluster out of ZX-2 is not the correct shape to fit in place of the standard cluster. Here's a cluster out of a standard Escort. https://www.ebay.com/itm/1999-Ford-...ash=item41dbb214eb:g:NDoAAOSwcgxaj6GT&vxp=mtr You could substitute your speedometer into this cluster and the mileage would still be correct. Here's a cluster out of a ZX-2 notice the difference in the styling at the bottom of the cluster. https://www.ebay.com/itm/98-03-Ford...ash=item1c549f4e80:g:5ukAAOSwrklVfwbC&vxp=mtr
    denisond3 likes this.
  3. kryztaly
    kryztaly New Member
    4
    Thanks! I went back and after explaining I removed the wrong cluster they told me to leave the cluster at the desk and go pull another one. I took 4K pictures of the back of it and went up to the LX hatchback and pulled it, it was only 100 miles behind mine :) so after removing the speedo and cranking the mileage to be accurate it works great!
  4. pextor
    pextor Moderator Staff Member
    5,911
    781
    Lancaster, pa
    You could also have swapped the speedometer section from one cluster to another to maintain the odometer.
    4cylinder likes this.
  5. steven777
    steven777 FEOA Member
    53
    6
    38
    well like a lot of information it is wrong i put a SR cluster in my zetec swapped sedan you have to take the guide tabs off the dash and mod the bottom tabs on the cluster change the dash wiring and use the seadan plastic cover the zx2 part has a small gap on one side will add pics when i get a chance
    99SseSPORT likes this.
  6. pextor
    5,911
    781
    Lancaster, pa
    These pics I gotta see.
    4cylinder and 99SseSPORT like this.
  7. steven777
    53
    6
    38
    i have some finish work to do but it fits fine will add another pic when im done (building another zetec swapped sedan)the sedans clear plastic will not fit may try to mod it
  8. 4cylinder
    4cylinder FEOA Member
    693
    126
    193
    san diego, ca
    this does not fit. with the finished appearance it is not worth the modifications needed to make it not quite fit as pictured.
  9. steven777
    53
    6
    38
    It is worth the 10 minutes to make the fill piece
  10. steven777
    53
    6
    38
    The finished filler panel will be gray this was just a preliminary part lost the first part i started on so had to make another it's not adjusted correctly but has to be bonded to stay in place IMG_20190718_1955171.jpg
  11. pextor
    5,911
    781
    Lancaster, pa
    I'm interested to see the final product.
  12. steven777
    53
    6
    38
    When it is finished I will add the pic its fairly easy the only hard part is the rounded edge on the right side
  13. steven777
    53
    6
    38
  14. steven777
    53
    6
    38
    when i get it in the car and cleaned up it will look awesome
  15. steven777
    53
    6
    38
    pretty much done just installed for the last time unnamed (3).jpg unnamed (4).jpg
