Have a studder like a mad man and a cel for 2nd cylinder. bought plugs, wires, distributor then pulled second plug and found the electrode with oil on it... So assuming piston ring or piston is messed and think its cheaper to get a motor from junkyard ($200) then pull all apart and replace parts. So can be done in a weekend and ready to go and has 30 day warranty so why not i figure. That said, i searched for a diy on pulling motor with no luck. any diys for the 2.0?
Any help is greatly appreciated. once motor is pulled and replaced, its turbo time
going to run 7 psi while the original motor is being machined and built for some real boost.
Thanks
Dale
Thanks
Dale
