Engine - problem coolant leaks | Ford Escort Owners Association (FEOA)
Engine problem coolant leaks
Discussion in '2nd Gen 1991-1996 1.9L SOHC' started by garyd, Oct 10, 2019.
  1. garyd
    garyd FEOA Member
    392
    21
    278
    it seems that i replace one expansion plug and another leaks. now the ones between engine and trans leak.
    anyone know the size or part number? i want to go brass
    car is a 1994 1.9l
    thanks
  2. Gamer92
    Gamer92 FEOA Donator
    3,441
    986
    263
    Southern Indiana
    Melling MPE187BR
  3. denisond3
    10,017
    2,759
    As far as I know, the freeze plugs for all 2nd gen LX escorts are the single 2-3/16" for the end of the block (accessible after the flywheel is removed) or the four 1-3/8" size for the others. Dorman sells the small ones as p.n. 555025, and the large one as p.n. 555051, both being made of steel.
    With my Escorts, I have replaced the OEM plugs with new steel ones from Dorman. I figure they should last another 20 years. The originals all lasted that long or longer; and had not begun to leak 'yet', though some looked bad from the inner side. On one of the engines I neglected to replace them, so am worried that one will start to leak someday.
    So far no leaks on any of the OEM heads. Most of mine now have rebuilt heads - and I hope the rebuilder took care of the couple of small freeze plugs in the heads.
  4. marclar
    8,882
    505
    seabeck WA
    is your coolant rusty?
    denisond3 likes this.
  5. garyd
    garyd FEOA Member
    392
    21
    278
    Coolant was ok as I changed it.about 3 years ago I had to do a freeze plug under the exhaust manifold as it was leaking. The car was kinda neglected before I got it. This past spring I noticed I'd have to check coolant often. 2 Thursday ago is when I fixed the one leak and started another. Been doing that since.
    I did a flush and that's when others appeared. I had rust pieces come out of peacock valve. I'm going to replace as many plugs as I can with brass
    I'm going to drop trans today
