1 - 7 of 7 Posts
a came accross a thread where someone had used probe struts and springs on their second gen but there was some work that needed to be done for them to fit and i guess the zx2's struts and springs will fit with little to no work at all. my question is which would be best?
1998 ZX2
I know somebody put Probe/MX6 coil-overs on a 2nd gen so it is possible. Some welding is required though.
The ZX2 ones are a direct bolt on provided you use the ZX2 front strut mounts.
Just go with The ZX2 stuff its all bolt -in. The probe stuff will not work in front with out spacers, and in the rear it will also need spacers I believe or one of the bolt holes relocated. Dont remember for sure
thanks for ur inputs. how much of a drop can i expect with the zx2's?
1998 ZX2
You aren't going to get any drop with stock ZX2 springs.
aight, thanks matt.
1 - 7 of 7 Posts
