Here´s a info story about Octane. Octane is a measurment of gases RESISTANCE to detinate. That is why if you bump up you timing it won´t ping as bad as with regular gas. But since octane is a resistance to detination, the lower numbers actually burn faster, making the cylinder pressures rise faster, and there for produceing power faster. Think about what you are doing when you advance your timing. You are igniting the gas when the piston is farther down the cylinder, and since it is on it´s way up, the sooner you ignite the fuel the more resistance it will have as it´s trying to come up, eventually to the point where you hurt performance. THe idea timing setting occurs when you ignite the fuel in enough time for it to completely burn and produce it´s highest pressure right when the piston hits top dead center. Remember, it´s not the spark that makes the power stroke, it´s the cylinder pressure, the spark just gets the ball rolling. So you best bet is to find the best timing setting for the lowest octane gas you can use. The only reason super high performance cars use high octane is because the cylinder pressure is already too high before the moment of spark due to higher compression ratio, or forced induction, that the commpressed gas will light itself and cause pre-ignition. If there are anymore questions, feel free to ask, because i can ramble for pages about Octane.
