Power Wagon Rebuild (page 9, 7/11/09) TWINS ARE ON!! | Page 17 | Ford Escort Owners Association (FEOA)
Discussion in 'Photo Forum' started by Josh_LX, Sep 10, 2008.
  1. alxdgr8
    alxdgr8 New Member
    3,053
    Seattle, WA (previously Greenwood, IN)
    Awesome Josh!
    What hapened with the blowers though? Decide to just go TT or is it still in the works?
  2. Josh_LX
    Josh_LX FEOA Member
    8,177
    338
    Onyourma,ma
    still going to do them, just deided that tuning it as is would be much easier.
  3. Tracer-X
    Tracer-X FEOA Member
    1,477
    186
    Tacoma, WA
    Any update?
  4. TheSilverShredder
    TheSilverShredder FEOA Donator
    422
    268
    Indianapolis, IN
    Thank you, i have been waiting so long for that video. :notworthy:
  5. Josh_LX
    Josh_LX FEOA Member
    8,177
    338
    Onyourma,ma
    got issues with the radiator fan... must wave wired it up wrong or something. AS such, can only run it for about 10 minutes or so, then the engine is at full temp and I have to shut it down. been putzing with the tune on it.
  6. kids-at-711
    kids-at-711 FEOA Member
    658
    5
    168
    863, FL
    update? i love older trucks, you have about 6500 pounds of pure respect there man, awesome job.
  7. treeps95gt
    treeps95gt New Member
    796
    st.catharines, ontario
    k its close enough to spring now, COMPOUND CHARGE TIME
  8. Josh_LX
    Josh_LX FEOA Member
    8,177
    338
    Onyourma,ma
    Been working on that... ;) as soon as its tuned good enough to drive around, the blowers are going on.
  9. scortin4life
    scortin4life FEOA Member
    405
    13
    168
    Harrisburg ,Pa
    Haven't check you out lately! Awesome!!! Great job and good thing you stucke with it. Damn thats cool!!!
  10. Josh_LX
    Josh_LX FEOA Member
    8,177
    338
    Onyourma,ma
    Gents, the beast is finished. Almost. lol.
    It runs, drives, and is a blast, unfortunately, the V8 didnt stick around. After trying like hell for about a month and a half to get it running properly, I got frustrated, fed up, and pulled it out. At the same teim, whoever runs the universe agreed with my idea, and a Cummins 4BT turbodiesel popped up on craigslist for 1200 bucks. I snapped it up, dropped it in, and it has been running perfectly since, with a few minor teething issues at the start. I am getting 18MPG with it to boot around town. Not bad for a 6500 lb truck.
    [​IMG]
    Idle is set high to make it easier to start the first time. Apparently, I didnt need it!
    [​IMG]
    [​IMG]
    [​IMG]
    Transmission mount: the engine does lean slightly to the passenger's side. Did it on purpose so that it matches the profile fo the floor better on the transfer case and lets me mount it higher in the frame to give me more ground clearance:
    [​IMG]
    [​IMG]
    [​IMG]
    ground cleanrance:
    [​IMG]
    Intercooler setup. My daily drive is a 2005 Audi TT Quattro 225HP model. It provided the inspiration to do dual side mount intercoolers. The intercoolers are from Ford Thunderbird Turbocoupes. I put 1100 CFM fans on each one pulling the air out of the coolers.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    And, the new floorpan mocked up. Thats the last part to finish. I have it all welded up (the metal version) just need to drill it for mounting holes.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    how to remove a bolt when you cant reach both sides, lol
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Old video, back when I first got it running... no throttle pedal even yet!
    [​IMG]
  11. Josh_LX
    Josh_LX FEOA Member
    8,177
    338
    Onyourma,ma
    I upgraded the engine with a bigger turbo, the HX35 off a 6 cylinder dodge, more aggressive fuel pin, turned up the pump, and added the intercoolers. It should make somewhere around 150-160 HP, not a whole lot of HP, but, it also makes north of 400 ft-lb!!
  12. Tracer-X
    1,477
    186
    Tacoma, WA
    So 150-160 x4 (2 supers and 2 turbos) plus what ever HP the engine is making?
    Doesn't the engine you have in there make about 400 HP stock?
    I am so confused!
  13. Josh_LX
    Josh_LX FEOA Member
    8,177
    338
    Onyourma,ma
    No, I yanked the V8. I couldnt get it to run right. Would be good one day, and complete crap the next.... was worse than a carburetor!
    The 4BT is a 4 cylinder version of the dodge 6BT 6 cylinder cummins diesel. it makes 100HP stock, and 230 Ft-lb.
    The 6 cylinder would be too long and heavy to fit in my truck. the 4BT weighs 800 lbs and is 35" long. The 6BT is 1300 lbs and 41" long!
  14. Bomdoutscort
    Bomdoutscort FEOA Member
    1,249
    10
    288
    Cincinnati, Ohio
    You shoud take some of those pipes off and have them powdercoated for ultragoodness!!!
  15. Tracer-X
    1,477
    186
    Tacoma, WA
    Not sure how I missed the whole last page especially since I posted for an update! 8O It all makes since to me now.
  16. white-lightning
    white-lightning FEOA Member
    2,896
    186
    Salem, VA
    Cool. Glad to see it is running good. That engine should be plenty as my A100 has around 260ft-lbs and hauls pretty good. 400ft-lbs has to be a blast especially with your low gearing.
  17. Cymmantix
    Cymmantix My old archenemy, RAKES!
    6,144
    211
    363
    NJ
    Great work as usual. The diesel is cool, and will pound out more torque than you can probably find stuff to do with. That said, I must admit a bit of disappointment to see that the twin-charged gas engine didn't work out. I would've loved to see what that thing could do unleashed.
