I recently found the 2-door PW/PL set-up and installed them in my GT. The door lock actuator will not work when plugged into the harness. The switch on the drivers door is good, the relay is getting power and you can hear it click. The plug for the actuator in the pass. door has power to it. The actuator itself will work if hooked up directly to the battery. But when I plug everything together, all I get is a click from both the relay and the door.
I contacted the local Ford dealer, and the parts are correct for the '95-'96 model years. The relay and door switch came out of a '95 wagon. The PW, wire harness and lock actuator came from a '95 GT. The parts guy said they were the same for all Escort body styles.
Anyone have any ideas?
