I recently started having a weird problem. If I shift into second after getting high rpms in First, half my power disappears, like I'm only running on half my cylinders or a rev limiter kicked in or something. The engine feels and sounds rough when this is happening. To get the engine out of this "no power mode", I have to let almost all the way off the gas, then I can floor it and all my power has returned, and I can resume second gear acceleration. Also, I've noticed that sometimes the needle on my tachometer dances around a little bit. Not sure if it indicates a problem or if it's related to the weird power loss.
I once held the petal to the metal in this no power mode for several seconds and the check engine light came on. I pulled the codes and it came back as 216 #2 Coil, but I'm suspicious... seems odd that a bad coil would behave in this manner. The engine light turned off right after I lifted off the gas.
Anybody have any ideas?
Here is a video link which may or may not help:
I normally shift prior to red line but I was busy with the camera.
The vid shows normal acceleration through first, then when I shift, into second I'm pretty much stuck at 4k rpms cause the power is to low to accelerate. I try letting off the gas a couple times but it didn't help, then finally around 21 seconds into the video, I let off the gas enough to get out of "no power mode" and am able to resume normal acceleration.
Edit: Turns out I don't have to shift for it to loose power, just need high rpm.
