I picked up a ZX2 with around 120,000 miles on it that needed work. It runs great HOWEVER from day 1 since I owned it there has been an engine knock.
I assumed that the knock was from a cold engine on start up and was coming from the solid camshaft lifters. It goes away once the revs go up. While looking for an exhause leak under the car, it sounded like it was coming from the bottom end, but hard to pinpoint where it was coming from. Again, once the rpm's went up, the noise was gone.
Are these symtoms of a bad con rod? If so, can I drop the oil pan and change the big end bearing?
Thanks
Canflyboy
Thanks
Canflyboy
