Sorry if this topic has been addressed elsewhere here but, i have spent several hours searching for some definitive answers re: IAC valve issues and would appreciate some more direct info if anyone could help with this:
My car was idling rougher lately than it normally does so, about a week or so ago,I cleaned the MAF and throttle body with electric parts cleaner and, TB cleaner,respectively,thinking the rough idle was possibly due to carbon build up and whatnot.Also checked for possible vacuum leaks and found none.Now this week the high idle won`t kick down and RPM`s hang before dropping to around 500 at idle.All this and no trouble codes.Took off the IAC and soaked it in carb cleaner,being careful of the solenoid,and cleaned the inside as best I could.I watched a youtube video last night where a technician tested the solenoid functionality by connecting the valve to a 9v battery to see if the valve actually functioned.I got nothing but clicking sounds from the solenoid by doing this.After reinstall no lasting improvement.turn on the fan or turn the wheel hard and car nearly stalls.
Now,does the 9v test idea hold true or is that bogus?
Could the valve simply need more than an hour to soak before becoming unstuck?
Should I soak it with PB Blaster or something similar instead to try and lubricate it?
If the valve is shot and I can find one at the salvage yard,what years are interchangeable ,if any?I`m not entirely sure that the IAC is the cause here so, it seems that a used one may be a better choice,in case it`s not the problem.
I found a new one on Amazon for around $47 shipped but,I`m in the middle of doing a timing chain on my wife`s car and need to save the bucks for that job.
Any help here would be greatly appreciated!! Thanks.
