Zeemax, glad you´re satisfied with your Pacesetter system so far. I´m sure those pics will help someone out too.
I also ordered a Pacesetter system from NOPI, and was equally impressed with the fast shipment, and also with the quality appearance of the Pacesetter system, although I also am not crazy about the yellow tips, mostly cause they really don´t go with my car, but yeah hopefully it´ll burn off or dirty up soon enough. It´s definitely louder, which I like, but sort of raspy sounding, not as deep as I´d prefer, but not like angry hornets either.
By the way, mine is a 1.9L, so maybe that´s why my experence is slightly different....
I had it put on at an auto repair chain near my house cause it was convenient. I was pretty unhappy with the results.....I had some wicked vibrations that weren´t there with the stock exhaust, especially when stopped in Drive. Maybe I should have taken it back to the same shop, but I wasn´t sure if the problem was the system not fitting right, or the installation, so I went for a 2nd opinion instead.
I (finally) found a shop that does custom exhaust, so I let them look at it. The pipe that goes side to side under the car was actually right against the car´s underside, hence the vibration. The whole system was back like 2" from where it should have been, like they hadn´t slid it far enough up. I´m not 100% sure the problem was the installation, because they fixed it by adding in a sleave of pipe at the front end so they could more easily slide the whole thing forward. Now the problem is like 95% fixed. It still somehow vibrates when I´m in reverse with the brake on, but that doesn´t bother me as much. I´m wondering if the problem could be the hanger that you had to modify.
