haha funny you should ask. Well, the first time I took the scort to the track;
I went to Firebird Internat´l Raceway, Chandler AZ. Elevation there is about 1600´ above sealevel. I weighed in at 2745lbs with myself and a 100lb passenger. The only thing I done to the scort then was the exhaust, and I was running on my pretty heavy 17´s. I ran a 16.7 that night at 83mph with a peak speed at 84mph. My R/T on that run was a .83. When I got back from the track I realized that my PCV valve was bad and was leaking oil into my intake manifold
The last time I went was less then 2 hours after getting the turbo installed with no tuning what-so-ever. We had to tech in by 9pm in Phx and we left Prescott here at 715pm. I teched in and parked. Found all my friends there, then my friend Rob got under the escort to adjust our spring on the wastegate rod. The WHOLE ROD WAS GONE. We lost it somewhere on the drive down. So I was running with about .5psi in 1st and 2cd, and about 1psi in 3rd and 4th. 5th was back to about .5psi. Alot of my friends starting talking trash because I wasn´t running my car, so Rob got pretty pissed and wired the wastegate halfway open with a coathanger. We pushed the scort to the line. He was running about 6psi with horrible turbo-lag. On video we have Rob barely moving the tires as the light went, then the boost kicked in and the tires broke loose, he shifted into second and our shim fell out....we were now running nearly no boost and full timing retard. After hitting the steering wheel a few times you can watch him cruise the quarter like the daily driver it is. He ran a 20.63 at 64mph, but with a 60´ time of 2 seconds
As soon as I can get the scort tuned right, I´m going to be running 8psi on the street and 14psi at the track. I dont really care what time I get, my goal is to break 100mph on a quarter. If I do everything right I´d like to run low 14´s to a really high 13 with a perfect .5 R/T
