1 - 5 of 5 Posts
I have a '00 zx2. I've put a full cold air kit on it, a catback and reflashed the pcm with the s/r tune. I was wondering what else I could do to give it a little more power. I'm not looking to go turbo or anything major. Just want a little more. Any ideas?
Getting a Kami/ZXtuner header, high flow cat (if you catback doesn't already have one) are probably the least invasive on your wallet. There's also a few things you can do with a focus head (must be Zetec), and beef up the internals with some SVT parts.
1998 ZX2
Headers are a good option on the ZX2. You can get a JBA or Pacester shorty header, both of those just bolt on with no modifications. Then there are the long tube headers you can find on ebay. They will bolt right in too but they do away with your cat so you may want to have one welded into your exhaust.
You could also go with an under drive pulley. The ones for the Zetech powered Focus should work just fine and they can be easily found for cheap.
1 - 5 of 5 Posts
