First, let me admit that I do not know a whole lot about cars, so my explanation of this may not be the best.
Okay, so I have a 1999 that for the last several months has been plagued by the dreaded "rough idle" problem. Like most of you, my idle gets even more erratic when I turn on the A/C...and as a result I am forced to put it in neutral.
Well, I have searched these forums for the last several days and I have compiled a list of things I am going to try to do to resolve this problem. I started yesterday by cleaning the MAF sensor and cleaning the throttle body. I also replaced the PCV valve.
However, the question I have is that when I was replacing the PCV valve I noticed that there was no elbow connecting the valve to the other line. The valve is connected directly to what looks like a container on one end, and directly to a hose on the other end (this hose is too connected to another hose which runs directly to the top of the gasket head)...but no elbow was present. So, I was wondering if there should be an elbow there, and if not could this feasibly be causing my rough idle problems? Also, I took the hose off that connects directly to the valve and it appeared to be cracked on both ends where it connects. I wondered if this was a big deal, and if so what can I do to reduce suction in this hose?
Thank you very much in advance for all of your responses.
