PCV hose that goes from exhaust manifold to firewall | Page 2 | Ford Escort Owners Association (FEOA)
Discussion in 'ZX2 1998-2004 2.0L DOHC' started by ddemier7, Feb 15, 2019.
  1. Racecar
    Racecar FEOA Member
    21
    9
    63
    Iron ridge Wisconsin
    The pictures that are attached to this comment. The plastic you are looking up at near the starter is the intake manifold. The pcv never goes into the firewall inside the vehicle. Those are different vacuum lines for the heating and a/c.
  2. Racecar
    Racecar FEOA Member
    21
    9
    63
    Also the plastic breather hose is still being used in their.
  3. Racecar
    Racecar FEOA Member
    21
    9
    63
    The stock breather hose is still there. I tried to circle it. And the make shift elbow goes on to the intake manifold and that is the end of it’s routing. So you just need the two elbows. At any part store. Labeled as Ford pcv elbow.
  4. Defunct SR Owner
    Defunct SR Owner FEOA Member
    27
    10
    I eliminated both elbows, in the front I use about 12 inches of vacuum line and go around the thermostat housing and coil and into the oem plastic line. I connect the oem line into the intake manifold using the same type elbow as the valve cover vent that pipes in front of the air cleaner.
  5. Defunct SR Owner
    27
    10
  6. ddemier7
    ddemier7 FEOA Member
    48
    5
    8
    Missouri
    Thats a good idea
