PCV hose that goes from exhaust manifold to firewall | Ford Escort Owners Association (FEOA)
Discussion in 'ZX2 1998-2004 2.0L DOHC' started by ddemier7, Feb 15, 2019.
  1. ddemier7
    ddemier7 FEOA Member
    48
    5
    8
    Missouri
    I need to the name or the part number of the PCV hose that goes from the drivers side exhaust manifold and runs down the drvers side of the engine then it goes behind the engine and turns into the firewall. I guess Ford has problems with the rubber elbows leaking?
    Can anyone help me out?
  2. Gamer92
    Gamer92 FEOA Donator
    3,440
    986
    263
    Southern Indiana
    If you just need the elbows then you can use the dorman 46027 for both ends. The tube is plastic and usually it’s the elbows that leak
    denisond3 likes this.
  3. ddemier7
    48
    5
    8
    Missouri
    I need the elbows and the pipe or hose. Does anyone have any ideas where to get some aftermarket pcv pipe or some hose. The path the hose takes is like the letter L so it has a 45degree bend in it.
  4. steve60tuesday
    steve60tuesday FEOA Member
    36
    17
    18
    I was just working on my car today... and I don't remember seeing any tube from the exhaust manifold to the firewall. I'm a novice at this stuff, but a tube linking the exhaust to the passenger cabin sounds like a tremendously terrible idea!
    There's a tube with an elbow that is known to fail, located behind the engine kinda by the starter. Is that what you mean? Fortunately (for me) mine hasn't broken yet, but unfortunately I have no idea how or where to source a replacement should it fail.
  5. ddemier7
    48
    5
    8
    Missouri
    First picture is the close up of the drivers side front part of the engine where the PCV (positive crank ventilation) rubber elbow which is part of the vacum hose that goes down the drivers side engine then goes behind the engine and to the fire wall. In the second picture I outlined in red the route of this vacum hose looking from the front bumper into the engine bay. This elbow and vacum hose is what I am trying to find even if it is aftermarket vacume line kit as shown in the third picture.
  6. Gamer92
    3,440
    986
    263
    Southern Indiana
    Is something wrong with the whole thing, or are the elbows just leaking?
    ddemier7 likes this.
  7. ddemier7
    48
    5
    8
    Missouri
    Ha ha yes somebody has used pipes (like you use on air compressors) as part of the PCV ventalation system behind the engine where it goes into the firewall. The elbow in the front part of the engine has crackes in it so I am just thinking of the best way to re-do this whole PCV vacum line. Trying to see if anyone else has re-done their PCV system.
    The picture I included are from under the car looking up at the engine. You can see the starter in the pictures. Somebody has used pipes as part of the pcv system probaly because the pcv ventalation hose is known to collapse where the hose has any bends in it from the manufacturing process. The oil residue that is found in the pcv blow by contains oil that can break down hoses over time and collapse them. Oddly enough this pipe contraption is actually working, however I don't want it to fail on me when im driving and im out of town.
  8. Gamer92
    3,440
    986
    263
    Southern Indiana
    probable going to have to get the it from a junkyard.
  9. ddemier7
    48
    5
    8
    Missouri
    There are no ZX2 around here in the junkyard. It cant be that hard to come up with a better idea than whats currently on it. Besides a junkyard rubber hose will probably be all weatherd and dry rotted.
  10. Gamer92
    3,440
    986
    263
    Southern Indiana
    its plastic with rubber ends. the part number for ends is dorman 46027 .
  11. ddemier7
    48
    5
    8
    Missouri
    Ok now I just need the part number for the plastic breather hose/tube. Do you know where I can get some?
  12. Gamer92
    3,440
    986
    263
    Southern Indiana
    Junk yard probably, cant seem to find it on rockauto
    do you have facebook? Someone on the teamzx2 pages may know the part number
  13. ddemier7
    48
    5
    8
    Missouri
    I will check that group out
  14. ddemier7
    48
    5
    8
    Missouri
    This group?
  15. zzyzzx
    14,985
    1,166
  16. Racecar
    Racecar FEOA Member
    21
    9
    63
    Iron ridge Wisconsin
    The PCV starts by the exhaust and goes into the intake manifold. Under the fuel rail and near the starter.
  17. Gamer92
    3,440
    986
    263
    Southern Indiana
    That’s one of them
    There’s about 5-6 different ones
  18. Gamer92
    3,440
    986
    263
    Southern Indiana
  19. Racecar
    Racecar FEOA Member
    21
    9
    63
    Based on the screenshots. It looks like the routing I described. It also has a plastic intake manifold.
  20. ddemier7
    48
    5
    8
    Missouri
    Plastic intake manifold back by the firewall? ?
