Cannot seem to find the replacement line that comes off of the PCV valve.
Did many searches and cannot locate, even through the Ford parts web site. Car was running rough, found the hose was collapsed from the vacuum, this hose was someones band aid. They outer sleeved the broken hard plastic line from the PCV valve to the canister with this flimsy hose. Anyone know where I can get this plastic line with the proper elbows (current PCV valve has no elbow) or should I just get some vacuum hose (that will not collapse) to replace this line?
