1 - 3 of 3 Posts
I have been having trouble getting the car out of Park. It has been giving a little trouble lately, and today, I couldn't get it to budge for about 10 minutes. I started to hear the Lock click and rattle when I took the car out of Park, and it is getting worse!
Any idea what the problem is, and if so, how can I fix it?
Thanks,
You guys have been great!
When you step on the break can you hear the parking lock disenguage to alow you to put it in a gear? If that is the case, jump under the dash and see if the break peddle switch is working right.
I got it! I couldn't hear the lock disengage, or even try to. I checked under the dash and the switch wasn't being released. It was pressed against the stopper. I screwed it down and it worked!
Thanks!
1 - 3 of 3 Posts
