i did the 20 swap and have to smog it but the evap is throwing codes when putting the 2.0 evap can on do i leave it in the back like the 98 wiring was or where do i put it and connect the hoses thanks
What year is the car? engine? You should have the stock canister and all its components. The vacuum line needs to be connected to the bottom of the throttle body. What diameter is the vacuum port on the bottom side of the tb?
