1 - 3 of 3 Posts
I know this is what the code means. Just not sure where to start with fixing it. I've replaced gas cap recently, replaced PCV valve, and run a can of berryman's through it.
Evaporative check solenoid circuit malfunction
Time to check the Solenoid, wiring and fuses.
Where is the solenoid, and what exactly does it do?
Oh, and go and get all the STFU noob stuff out of the way.
Evap begins at fuel tank all the way to the front left to a canister and from the canister to under the throttle, not to forget a valve and sensor.
I have 1443 lowering fuel tank and replacing all lines are on queue.
1 - 3 of 3 Posts
