Sorry,there is no such code.There is a:
P0442 - EVAP Control System Leak Detected (Small Leak)
The PCM monitors the complete EVAP control system for presence of a small fuel vapor leak. The system failure occurs when a fuel vapor leak from an opening as small as 0.10 cm (0.04 inch) is detected by the EVAP running loss monitor test.
Possible causes:
After-market EVAP hardware (such as fuel filler cap) non-conforming to required specifications,
Small holes or cuts in fuel vapor hoses/tubes,
Canister vent solenoid stays partially open on closed command,
Damaged, cross-threaded or loosely installed fuel filler cap ,
Loose fuel vapor hose/tube connections to EVAP system components,
EVAP system component seals leaking (EVAP canister purge valve, fuel tank pressure sensor, canister vent solenoid, fuel vapor control valve tube assembly or fuel vapor vent valve assembly),
And then you have :
P0402 - EGR Flow Excessive Detected
The EGR system is monitored for undesired EGR flow during idle. The EGR monitor looks at the DPF EGR signal at idle and compares it to the stored signal measured during key ON and engine OFF. The test fails when the signal at idle is greater than at key ON engine OFF by a calibrated amount.
Possible causes:
EGR valve stuck open ,
Plugged EGR vacuum regulator solenoid vent ,
Plugged EGR tube,
Slow responding DPF EGR sensor,
Damaged DPF EGR sensor,
Improper vacuum hose connection,
Plugged vacuum hoses,
EGRVR circuit shorted to ground,
Damaged EGR vacuum regulator solenoid ,
Damaged PCM,
A DPFEGR PID reading that is greater at idle than during key ON and engine OFF by 0.5 volt or a rough engine idle, may indicate a hard fault.
Or:
P0420 - Catalyst System Efficiency Below Threshold (Bank 1) Indicates Bank 1 catalyst system efficiency is below the acceptable threshold Use of leaded fuel
Possible causes:
Damaged HO2S
Malfunctioning ECT
High fuel pressure
Damaged exhaust manifold
Damaged catalytic converter
Oil contamination
Cylinder misfiring
Downstream HO2S wires improperly connected
Damaged exhaust system pipe
Damaged muffler/tailpipe assembly
Retarded spark timing
Compare HO2S upstream & downstream switch rate. Under normal closed loop fuel conditions, high efficiency catalysts have oxygen storage which makes the switching frequency of the downstream HO2S quite slow compared to the upstream HO2S. As catalyst efficiency deteriorates, its ability to store oxygen declines and the downstream HO2S signal begins to switch more rapidly approaching the switching rate of the upstream HO2S. Once beyond an acceptable limit the DTC is set.
Wich one is it?
