I have a 1994 Ford Escort Wagon, 1.9 Liter, Automatic, AC, and PS.
I recently purchased it for $550.00, with the plans of getting it in tip top shape to have a fuel efficient vehicle to drive back and forth to work.
Upon purchasing it I had to do the following to not only fix a rough idle issue, but give a general tune up.
New Motorcraft Plugs, and Plug Wires.
New Motorcraft Oil Filter, and Castrol 10w30.
New Motorcraft Fuel Filter.
New Motorcraft PCV valve.
New Intake Manifold Gasket, and Many Many new vacuum lines!
Upon starting it after the general tuneup, I could tell right away that it helped.
Not only did replacing the manifold gasket help the rough idle, but it now idles so smoothly you can barely tell its running
8)
But one problem:
When I had everything tore apart, I decided to go ahead and change thermostat, and Gasket.
So I continued on about changing it with a Motorcraft OE thermostat. I did manage to break 2 of the housing bolts. But was able to pull one with vice grips, and use an ez out on the other. I ended up using a self tapping screw on one of them with a heavy dose of RTV. There are no leaks, and everything is running fine.
BUT ONE PROBLEM.
On the Temp gauge on the dash, The gauge is reading that it is running cool. It is only getting to a little before the N on the Normal reading on the gauge.
The heat will run you out of the car. It works great.
The hoses are hot to the touch.
MPG is around 34 on curvy state hwys.
The thermostat, housing gasket, and pressure cap have all been replaced.
When I filled back up with antifreeze I balanced out a 50/50 mixture, and it tested good to -45 degrees F.
The connections on both of the the coolant temp sensor, and sender appear to be tight.
I have searched and searched and Here is what possible problems could be:
Radiator--Radiator appears to be clean and free flowing
Pressure Cap--The cap is new, and has been replaced.
The coolant mixture has been tested several times, and results show that it is balanced right.
Any advice???
8)
But one problem:
BUT ONE PROBLEM.
Any advice???
