So i was trying to locate a rough idle problem and had read that you can take out the spark plugs and look inside for a loose valve seat or something, so i took out a couple of spark plugs, put them back, not my engine is 'jumping'. only when i'm accelerating.
I did a quick search and think it might be that i've not put one of the plug wires on correctly, one other thing is that i added some fuel injector cleaner to my gas tank.
Its too late to do anything tonight, but do you think if i replace the wires from the distributor to the plugs it might solve my problem?
one other thing that i should add is that when i had one of the spark plugs removes i crancked the engine, i guess this might have messed up the timing?
