Do we have a cable-actuated clutch or a hydraulic one?
The reason I ask is because someone is trying to answer my problem and asked that.
This is my problem.
I've been having problems this week. First the car doesn't seem to want to leave 1st if I stay in it for more than a few seconds. And when it gets stuck, I have to turn it off, pump the clutch and then shift it out. If I'm moving and it gets stuck (even if I didn't ride 1st) I can get it out of 1st but it takes some pushing. Today I was parking and when I stoped, I couldn't get it out of gear. But I noticed that when I let go of the brakes, even with the clutch all the way through, it started to move foward (I was parked in an incline so it should've gone back not foward.)
Once I turned it off, and pumped the clutch, I was able to shift without a problem and on 1st with the clutch on, the car acted normal.
What could be wrong? I've thought that the syncro's were having problems at first (because my rear has been hard to get into for some time.) And then I thought that I needed a tranny flush, because the junk can make it act the same as a syncro problem. Somebody help. It still drives normal most of the time, but I want to fix whatever it is before it becomes something big.
This is my problem.
