Just for the 1st gen guys...seen this posted in other sections.
Ford specifies 5w-20 for '91 and up CVH engines. I'm wondering if anyone here has tried that?
Personally, I've been using 5w-30 year round. I never actually read what Ford recommended for the late model 1st gen engines, I just went with 5w-30 because it was easy to find, and never had issues in my engine. I've been wondering if 10w-40 would improve things or not, as Ford recommends it until -10F all the way up to 100+F air temps. I can say that on hot days my oil pressure dropped a little, but that was with the 400S filter. Has anyone tried the different weights and seen a difference in fuel economy, engine smoothness, or power?
Another thought is this: Ford specs the 1.6 and 1.9 as taking 4 quarts of oil with the filter....my dipstick registers me as being a half quart low then, and about 1 quart when using the FL-1A. Has anyone else had this issue...wondering if my car has been cobbled to the point of having some wonky oil dipstick.
Another note: found out the 400S filter was spec'd by Ford to flow 3 gallons per minute without bypassing. The FL-1A is spec'd for 7 gpm, and that it seems the stock Motorcraft ones are the same stuff as a PureOne filter...makes it a cheap way to get some great filtering.
