Engine is 1.9.L
I recently rebuild my engine everything works fine except nometter what I
do my oil pan is leaking. I drives me crazy. I took it off like 3 times already. In first I used just a gasket. It leaked. I took it off and used gasket plus blue selicone. It still leaking. Everything is done with proper procedures. Like cleaning with acethone and etc. The spots where it´s leaking from are where accessory pully is and on the other side where flywheel is. Someone told me that for new gasket I need to torque it little bit more then 15-22?. Plz if someone had the same problem and you fix it somehow...HELP!
