Here are the spec from K&N
Now my question is about the relief valve. I know the oil pressure in my car is suppose to run higher than the 11-14psi at which this valve opens. When does this valve open, no way does it open at that psi otherwise it will never filter?Part HP-2009 Product Specifications
Product Style: Oil Filters
Height: 5.08 in (129 mm)
Outside Diameter: 2.99 in (76 mm)
Thread Inside Diameter: 0.75
Thread Number: 16.00000
PSI Relief Valve: 11-14
Anti Drain Back Valve: Yes
Style: Canister
Weight: 0.8 lb (0.3 kg)
Product Box Length: 3.15 in (80 mm)
Product Box Width: 3.15 in (80 mm)
Product Box Height: 5.14 in (131 mm)
