1 - 4 of 4 Posts
Ok, first off sorry if I missed this somewhere. Didnt see if in the Sticky. Searched and came up with nothing about wheels. But here it is.
If I'm looking for new rims, I understand the +1 +2 stuff for the rim size, but if I'm searching for a rim say on EBay, I'd look for a 15" rim with an offset of +38 and bolt pattern of 4x100 for a Gen 3 Escort, correct? I saw that the stock offset is +38. Is there any other pertinent information that I'd look at or should anything that comes up as +38 offset and 4x100 bolt fit?
Also is the width of the rim important as long as the offset is correct?
i would just like to say, though im no escort expert, if you go with a more aggressive, significantly wider rim, you will want to get a lower offset so you dont rub things inside the wheelwell.
1 - 4 of 4 Posts
