oem ford part numbers | Ford Escort Owners Association (FEOA)
Discussion in 'Part Numbers' started by 4doorscort, Jan 27, 2008.
  1. 4doorscort
    4doorscort New Member
    8,129
    5
    Brampton ON
    if anyone needs oem ford part numbers, my dad works at the ford plant in brampton here, and works with this stuff, if anyone needs one, he can look it up.
  2. ford_obiwan
    ford_obiwan New Member
    303
  3. 4doorscort
    8,129
    5
    Brampton ON
    yeah, well if anyone can't find what there looking for there, pm me.. I remember I couldn't find something there before
  4. richconw94gt
    richconw94gt New Member
    I work at a Ford dealership in the parts department, I too can help with parts if anyone needs.
    :D
    Thanks
    Rick
  5. tweakers
    tweakers FEOA Member
    295
    266
    Plano, IL
    5spd manual tranny parts for the gt. 3rd&4th collar, oem# : E92Z7106A ive already called transtar but the guy couldnt find it. also looking for 1st&2nd collar as well P#: E92Z7105C nvm, its going to be mazda #s
  6. plyrh8r1
    plyrh8r1 FEOA Member
    330
    8
    268
    chicago heights,IL
    im looking for part numbers for the bushings for the rear lateral links and rear control arms for a 94 escort gt
  7. Sketch
    Sketch You Tube Tuner-vana
    304
    4
    178
    Dyer, Tn
    I need to know how to tell if my pistons are coded red or blue.
  8. techkyle
    techkyle FEOA Member
    28
    151
    Northwest Washington
    If you could find the part numbers to the various ECUs used in the second generation Ford Escorts, that would be awesome.
  9. 4doorscort
    8,129
    5
    Brampton ON
    can't get neither of those
  10. pnmred
    pnmred FEOA Member
    306
    27
    178
    MIDWEST
    1996 lx wagon mtx, the metal tube/hose from the thermostat housing to the heater core, I tore the hose, and it looks like the whole part is meant to be changed as an assembly, anybody know the part number or method of replacing the rubber hose?
  11. DaveH
    DaveH FEOA Donator
    13
    63
    Coldwater, Michigan
    I own a 1987 Escort GL, four door station wagon, SOHC 1.9L EFI, ATX tranny, PS, PB, without A/C. I'm currently changing the worn out rocker arms w/Sealed Power R-1053 Rocker Arms. The Sealed Power Kit provides a nut for a stud set up, I have the bolt set up. I'm not able to find someone who has the bolts. The bolt in SAE is 5/16 "-20 x 1-7/8 Class 9.8 Flanged Hex Head (8 mm-??thread pitch in mm x 47 to 48 mm in length). Does anybody know the part number from Ford or any other manufacturer so that I can look them up online?
  12. Deadman
    Deadman FEOA Member
    287
    21
    278
    Maine
    I have a question for you ford dealership guys. I have a 98 Lx 2.0 sohc and needed a new pcv valve tube assembly so I called the guy in parts and he said the new replacement for this did away with the Pcv all together. Is this true?
  13. Gamer92
    Gamer92 FEOA Donator
    3,460
    997
    263
    Southern Indiana
    There are 3 setups for Escorts. If you have the one where the PCV is in the middle, then that one should still be available at dealer. I was able to get mine in 2012. I can check my dealer and get a part number if you'd like.
    The top photo in this pic is my setup.
    https://www.feoa.net/threads/where-is-the-pcv-valve.40630/
    Some list of part numbers
    https://www.feoa.net/threads/pcv-valve-hose-broken-help-asap.47797/
  14. Deadman
    Deadman FEOA Member
    287
    21
    278
    Maine
    Yea mine is in the middle like that. I don't have faith in the Goober I had on the phone so sure if you wouldn't mind getting the part number of the whole thing together.
  15. Gamer92
    3,460
    997
    263
    Southern Indiana
    Sorry I never got a notice for your reply. I will check my local dealer tomorrow and let you know the part number.
  16. Gto87
    Gto87 FEOA Member
    35
    158
    I sent you PM.
  17. barlul
    barlul FEOA Member
    244
    41
    28
    Edna, Texas
    Can you help me find the bolts holding the manual gear shift control rod to the gear shift lever (stick) and the one for the shifter shaft at the tranny to that same end of the gear shift control rod? The middle connection on the gear shift control rod is riveted and I found a kit for it. The only number I have for the bolts at each end of the gear shift control rod is #78366. Isn't this part of the Ford part number?
  18. barlul
    barlul FEOA Member
    244
    41
    28
    Edna, Texas
    http://www.discountfordpartsfromsoundford.net/ford-parts/
    This site has parts I couldn't find anywhere else_including Ford_if anyone is interested.
    They list a bolt holding the shift shaft (from the tranny) to the tranny end of the gear shift control rod (Ford part #F2CZ-7B366-AA). I think this bolt also holds the other end of the gear shift control rod to the shift lever (stick). The nut for this bolt is Ford part #90901-0811 and is supposed to be the same for Mazda. I include the response from my nearest Mazda dealer parts person and appreciate him trying to find parts for me.
    Barbara ,sorry it took so long to contact you back.
    it seems to have come to a dead end because
    there is no vehicle application that I can cross reference the
    Ford Escort to a Mazda model. however the parts may fit and
    function, I just cannot guarantee the reliability in your application.
    the nut part #90901-0811 from Ford is the same as Mazda, and the
    bolt F2CZ-7B366-AA does NOT cross into anything Mazda offers
    . I have
    contacted all my Ford associates that I know, and get the same response.
    that part is obsolete and no longer available. again my apologies for
    taking so long on the response to this and I wish that I could have been of
    more
    help. call me if you have any other questions
  19. Lizzie94
    Lizzie94 FEOA Member
    394
    85
    58
    Need part # for EGR valve for a '94 1.9L.
  20. denisond3
    10,076
    2,802
    I recently ordered a new EGR valve for my 94LX wagon from rockauto(dot)com. I dont have any idea of the Ford part number though.
