so last month i noticed that when i slow down in my car, usually at any rate of speed, that a clunk comes from the passenger side of the car. some days you can barely here it or feel it and others you think soemthing jsut broke with how loud it can be.
now ive looked under the car checked the ball joints (which are brand new) and the cv shafts and they seemed fine, i couldnt get a wiggle or an irregular twist out of them. the lower control arm is in good shape, so i doubt that its the problem
all the motor mounts are fine, none of them are loose, particualry because as a precaution i did tighten them up, thought they barely moved
any thoughts on what it could be?
