O2 Sensor | Ford Escort Owners Association (FEOA)
O2 Sensor
Discussion in '2nd Gen 1991-1996 1.8L DOHC' started by joeselb, Sep 26, 2004.
  1. joeselb
    joeselb Guest
    15
    Can anyone tell me what would be a sign when O2 sensor is going bad ?
    Thanks in advance.
  2. escortlx96
    escortlx96 Guest
    680
    Do you have your check engine light on?Are you losing gas mileage?
  3. mp3scort
    mp3scort Guest
    471
    if you are losing gas mileage, power, or have a MIL, (Check Engine Light(MIL = Malfunction Indicator Light)). a good rule of thumb is if your car is older than 1990, change every 45,000 miles, 91-96, every 60,000, and 97 and up 100,000.
  4. joeselb
    joeselb Guest
    15
    Yeah, the Check Engine Light came on today. I've checked and gone over the vacume lines, seems to look good. When I have time from work tomorrow or sometime this week, I'll head to Auto Zone, and have them run a check.
  5. highanddry
    highanddry Guest
    8,446
    5
    The most common cause for any vehicle's check engine light to come on is a failing/failed O2 sensor. They've got a tough job to do; it's hot in there. Other than your CEL/MIL illuminating, you may not notice any symptoms (poor fuel economy, loss of power) at all.
    If your CEL is coming on 5-10 minutes after you start the car, I'd bet on your O2 sensor. Very easy to replace; just use lots of penetrating oil.
    My truck's CEL automatically comes on every 145,000 km to remind me to change it. Sounds like a good idea, eh :idea: ? The problem is you have to pull the cluster to reset it :!: .
