1 - 8 of 8 Posts
On my '91 EGT fan belt squeals on starting up first thing then just slight noise through the day
have adjusted it and sprayed but still happens
now i'm starting to think it's the alternator pulley that squeals
which one do you think is correct? thanks dave
have replaced the belt and alternator in the past year
· Super Moderator
Best way to figure it out is take the belt off and spin the pulleys by hand.
'95 Wagon & '96 Pony
On the '56 the sides as the inside does not contact the pully. For the Escort's serpentine belt I'd guess all over to be sure. But now that you mentioned it I think I'll experiment with that and try one side at a time. Right now there is still salt on the roads so Mr. White will stay parked a little longer
1 - 8 of 8 Posts
