Just bought a 91 EGT (5spd), which has an odd power issue. It idles just fine (approx 5-600 RPM, hard to tell since the tach is off by around 1500), but has NO low RPM power. Even when I try to take off at higher RPM, the trans brings the motor down to lower RPM and it just won't get up and go. Once it builds some RPM, it pulls fine (though it might still be a little down on power there, and it just feels right comparatively). Seems like above 2k-2500 is when it picks back up, but it's hard to tell with the funky tach, might be more like 3k.
Thought it might have been the duct tape special intake hose and nasty air filter, but with the good stock hose out of my dead 93 and a brand new air filter it seems only a little better.
Guy I got it from said he did the timing belt himself, and he thought he had the timing right, but I'm wondering if maybe he was just a little off, either way. Could timing cause these symptoms?
